Part numbers.???
I have a numerical parts price list published in 1946. which should cover all Hudsons from1927 thru1946. The closest I could find was 157382..Sping cover assy. rear LH, front RH, Fits model 89,90 which was 38-39 Hudson 112
Thanks superDave,I have the same books and came up with the same,but,no number I was looking. for either.,0
157381 is the forging number for the "short" stroke engines, 1938-1942.
157369 is for the 212 cu 6 cyl. and 254 8 cyl.0 -
Thank you Ric,they certainly are the short stroke rods by measurement.0
I assume you realize that the shorter rod is for the longer stroke engines and visa-versa.
F
- 104 Essex Super 6
