Distributor questions
Yes you can. There may be some variation in the degrees of advance, but as a "get you home" it will work fine.
Thank you Geoff is there anything special I would need to do it? I was thinking of putting a set of points in it as it has none. I have the pertronix in my 39 now but if that fails along the way I would like a back up0
Would pay to check the condition of the advance springs. A set of points and a condensor should get you going.
Ok thank you so much0
