Sourcing Parts - 1950 Hudson
I'm new to this forum, so if you would advise separate posts for my parts questions, please suggest away!
I'm working on a 1950 Hudson Commodore Convertible, and am trying to find good sources for the following replacement parts:
1) hood release cable (the current one broke and we've turned it into the backup hood release)
2) an o-ring for the hydraulic fluid reservoir (the current one is cracked, stretched, and leaking)
3) spring for the clutch pedal return
Please advise. Thanks much!
  • Welcome
    use my website for vendors
    http://hudsonrestoration1948-54.com/
    Check Lance Walker for spring.  Contact info listed  on site
    the hydraulic seal should be sourcable at a seal company.
  • I've got the release cable as well as the outside frame clutch return spring.  Hydro electric in Florida has the top pump parts.
  • Lance, can you private message me and let me know how to contact you to order those parts? Thanks!
  • If you need to get a hold of me use HEThornetllw@yahoo.com    Drop the HET when writing.
