Sourcing Parts - 1950 Hudson
I'm new to this forum, so if you would advise separate posts for my parts questions, please suggest away!
I'm working on a 1950 Hudson Commodore Convertible, and am trying to find good sources for the following replacement parts:
1) hood release cable (the current one broke and we've turned it into the backup hood release)
2) an o-ring for the hydraulic fluid reservoir (the current one is cracked, stretched, and leaking)
3) spring for the clutch pedal return
Please advise. Thanks much!
Welcome
use my website for vendors
http://hudsonrestoration1948-54.com/
Check Lance Walker for spring. Contact info listed on site
the hydraulic seal should be sourcable at a seal company.
I've got the release cable as well as the outside frame clutch return spring. Hydro electric in Florida has the top pump parts.0
Lance, can you private message me and let me know how to contact you to order those parts? Thanks!0
If you need to get a hold of me use HEThornetllw@yahoo.com Drop the HET when writing.0
- 120 Hudson 1916 - 1929
- 612 Vehicles
