Silly Question
Mine (1937) doesn't. Funny that no one at the factory considered that some people wanted to listen to the radio while the car was stopped (without overheating the coil and burning the points, that is)
my 35 Terraplane doesn't0
I thought the first year for that was '52, when the starter got moved to the key, but not positive.0
My 1910, 1922 (oh wait no radio), 1937, and 1946 do not have accessory positions.
Jay
Couldn't you rewire it to just turn the radio on and off with out the key in the on position and save the points ?0
I just wired a switch that is mounted discreetly under the dash. I use it regularly when I would rather listen to the radio than be in a clothing shop!0
Thanks to all who have responded thus far. I have spoken with someone at Wildrick's and was told that since I have the push button start that when I turn the ignition key that is my accessory setting. The reason I am asking is that my wife wants to go to the drive in theater in the car on old US 66 near here. I thought that would be great as I can use my IPOD for the FM radio receiver considering I have the original am radio in the car. But not wanting to burn the battery or have car running the whole time I was concerned. As for the points, well I have none, I went electronic ignition on it. But ernie28 I would be most interested in what you did and how. Please advise.0
So, were guys like "wow, why didn't I think of that!" when accessory settings first came about? LOL...0
Val, I took a power feed from the fuse block to the switch and then just laced a wire to the radio feed wire. To save stress on the ignition switch I have a relay in the standard feed to the radio so there is no way the power can feed back to the other circuits in the car.
A very simple and easy mod with a discreet switch to not spoil the dash.
Good luck with this if you use this method.0 -
Thank you Ernie28, I appreciate the info. Would you please get me a diagram as I am not an electrician by no means of the word. : )0
Hi Val
I have drawn a rough diagram of the relevant circuits. Hope you can make sense of it and if not just ask the questions. Good luck.0 -
Thanks Ernie28 I appreciate it. I'll be in touch as I said I am in no way an electrician.0
- 104 Essex Super 6
