Front suspension upper/lower arm - special tool for aligning pivot and bushings ?
Doctorvaux
edited June 2017 in HUDSON
Hello,
there is excessive wear in the upper arm pivot/bushings on my 1948 super six, and I need to replace them. According to the Hudson manual, I should use tool 1860, which apparently spreads the arm by 1/16 inch to get the alignment correct.  As I am never going to find the correct tool (!!) has anyone improvised a way to get the alignjment correct ?  Any help would be much appreciated.  Thank you.
