Parts and parts
dont happen to have the side stainless for a 51 four door hornet would you? complete left and right side.
Also some door sills to suit a 49 four door.
thats a lot of old treasure man.0 -
yes on the sills-fair shape at best-need measurements and pics on the trim0
Car has a new York tag on it ???0
Steven, do you have any Twin H Power emblems for the trunk?0
I'm trying to build an intake for a supercharger system I'm putting on my '49. I could use an air cleaner to cut up.
How much would you want for the worst looking one you have, like the one I have circled in the attached pic?
I'm in NJ 07506
Thanks0 -
I am looking for the ss trim strip and support for the hood scoop for our 54 Hornet Ray
I am open to realistic offersairbrushguy said:I'm trying to build an intake for a supercharger system I'm putting on my '49. I could use an air cleaner to cut up.
I'm in NJ 07506
Thanks0 -
Hi, I am looking for a pair of rear fenders for a 1948-1950 2 door. I am also looking for a rocker panel for the passenger side. Do you have any please? There appeared to be some fenders in one of the pictures, but I could not see if if they were for the 48-50 models. Thank you.
I have a set but I thought all stepdown coupes were the same?0
2nevets - the rear quarters for 48-53 are all bolt on, BUT the bumper cutout at the rear of the fender makes them different for select years.0
There is a bluey/green rear fender in your picture with a hole for the rear lamp, so I would suspect that one is for a 52/53. If you have fenders without the hole and with the cut away for the rear bumper, then they would be for earlier cars. Please let me know if you have the early ones. Thamk you.
thanks for the headsup!Oldfarmer1947gmailcom said:2nevets - the rear quarters for 48-53 are all bolt on, BUT the bumper cutout at the rear of the fender makes them different for select years.0 -
I do-how bad are yours? mine need some workDoctorvaux said:There is a bluey/green rear fender in your picture with a hole for the rear lamp, so I would suspect that one is for a 52/53. If you have fenders without the hole and with the cut away for the rear bumper, then they would be for earlier cars. Please let me know if you have the early ones. Thamk you.0 -
My fenders have already been repaired, but not very well. However I was hoping to find some better panels without dents or rust. How much work do the your fenders need ? The red fender in the picture appeared to be quite solid ? I live in the UK so I was hoping to find panels that were quite good to make it worthwhile to ship them all this way. Do you have any rocker panels for a 2 door ?
Thank you.
These are not worth the trip with the exception of the red one-Doctorvaux said:My fenders have already been repaired, but not very well. However I was hoping to find some better panels without dents or rust. How much work do the your fenders need ? The red fender in the picture appeared to be quite solid ? I live in the UK so I was hoping to find panels that were quite good to make it worthwhile to ship them all this way. Do you have any rocker panels for a 2 door ?
Thank you.0 -
looking for a Twin H intake for a 308, don't need the carbs or linkage
Dave
I have a couple but I don't think they are for the 3080
I'm not sure of what all you have but if you have any trim for the hood of a 1946 Pickup I would be very interested. Also looking for a newer year steering column out of a step down to utilize for the turnsignal controls in my truck.
V/R,
Ryan0 -
I believe I have a column0
Do you have any jet parts?0
I have a bunch of 54 jet trim0
Do u have pics0
No not yet0
I will be vending at fall carlisle if anyone needs anything0
Hey,
Whats in the collection for overdrive transmissions?
Thanks,
J0 -
I have a few-any casting numbers you can provide?0
- 111 Hudson 1916 - 1929
- 570 "How To" - Skills, mechanical and other wise
