Flywheel nut torque for 54 308 engine with hydramatic and any need for sealant?
Doctorvaux
Can anyone tell me the torque to tighten the 6 dome nuts (3/8 UNF) that hold the flywheel to the crank for a hydramatic equipped 1954 308 engine please. The Hudson shop manual only seems to quote the 8 cylinder engine (40 - 45 foot pounds). Also , is there any need to apply sealant between the crank and flywheel to seal the transmission fluid in the Torus ? If so what sealant would you recommend. Thank you.
You do need Sealant in-between flange & flywheel. I would use a little Permatex Blk RTV or similar. Those Nuts are 3/8" SAE so I torque 45- 50# using Red Loctite then bend over the lock Tabs
Thank you !
- 104 Essex Super 6
