'29 Essex Uni-joints
Hi All,
Looking for replacements for my driveline uni-joints for the '29 Essex, Spicer here in Australia don't recognise the embossed numbers, the online tool at Dana isn't showing a solution. The usual google search isn't producing anything useful.
Any thoughts ?
Thanks,
Darren
Any thoughts ?
Thanks,
Darren
There are no direct modern replacement joints for these. Only option is to go to an engineering shop and get the drive shaft modified using modern joints.0
Does it mount to the trans. and diff. the same as a 1930 Hudson? I recently had one made.0
Yes, virtually identical set-up as 1930 H, just shorter length.0
Thanks Geoff, that seems to be the way I will need to go.
That's the ticket, I was making some from Aluminium bar.
Thanks !
