'29 Essex Uni-joints
oldie28
edited March 2018 in HUDSON
Hi All,
Looking for replacements for my driveline uni-joints for the '29 Essex, Spicer here in Australia don't recognise the embossed numbers, the online tool at Dana isn't showing a solution. The usual google search isn't producing anything useful.
Any thoughts ?
Thanks,
Darren
  • There are no direct modern  replacement joints for these.  Only option is to go to an engineering shop and get the drive  shaft modified using modern joints.
  • Does it mount to the trans. and diff. the same as a 1930 Hudson? I recently had one made.
  • Yes, virtually identical set-up as 1930 H, just shorter length.
  • Thanks Geoff, that seems to be the way I will need to go.
  • Here are some pics of my new 1930 Hudson driveshaft.
  • That's the ticket, I was making some from Aluminium bar.
    Thanks !
