Any Stepdown Sedan 3-Point Front Seat Belt Photos?
Hudson_in_Seattle
hi - i have seen lots of posts about seat belts front and rear in stepdown sedans - a few owners stated they had 3-point seat belts for the front seat, with one anchor point on the "B" pillar - i would like to see some photos of this install, advice, tips, etc - thanks, b
I would be interested in this as well as its something I will be doing a bit further down the track.
Wouldn't of thought it would be too tricky though.0 -
I believe Richard Dryman has 3 point harnesses in his car. You could maybe ask him for photos? He's active on the Facebook page, if that helps you.0
I tried to install 3pts in my '54 coupe but the distance from the B pillar to the buckle just was not right so I punted and went with lap belts.0
These were in car when I got it.
edit>> note that the reel prevents the seat from being moved all the way forward.
If you are real short, there will be a problem with that.0 -
If this link works--whoops
Keith, that's a link to the file on your PC. You'd either need a link to a file that's hosted on the web somewhere, or to attach the file directly to the post using the button above the text box that looks like a piece of paper with the corner folded.0
Here is one from Ken U, I believe. I've been saving it for my '50.
I'm sure he won't mind.
thanks for these photos - this is very helpful - i haven't seen an attachment point like that on these belts - i usually see a welded nut - i will look at mine when available if a few days - then off to my metal guy to help with the install - thanks again
Take a look at what Kiwis have to deal with when it comes to seatbelts. (one small part of certification process)
Below is a link to the requirements that must be meet just for seatbelt to let our cars be aloud on the road.
https://www.lvvta.org.nz/documents/standards/LVVTA_STD_Seatbelts_&%20Seatbelt_Anchorages.pdf
May seem a bit OTT but it keeps our cars safe I guess. And its kinda handy to know what thickness steel to use where. Rivets to attach I would be instant fail here.0 -
thanks very much!
Ken, where did you purchase the B piller nut plate ?
OMG, Kustom, this is giving me a headache!
OMG ...me too. All this to protect ourselves from.... our selves! and I thought our government was over bearing!0
hi checked on my hornet today and the upholstery on the B pillar is formidable - my first rule when working on cars is "don't break it" so i may seek some professional assistance (not psychological) to finish this project - thanks again!
- 120 Hudson 1916 - 1929
- 612 Vehicles
