Mallory Distributor electronic ignition conversion
Trigger your favorite flavor of ignition module with the points. I ran a points triggered HEI before I put the Chrysler Slant Six distributor in. Takes the load off the points and makes them a simple switch. Need to make a bit of a circuit for HEI. I think the Ford units can be directly triggered without too much trouble.
Welcome to Molly! Congratulations to Mom and Dad❗️0
I use Crane Fireball Point Eliminator Kit XR300/700 available on eBay for around $100+/-. It has a small 'Trigger' that goes where the points were with a slotted washer under the Rotor. It has a small Module mounted on the firewall with all plug-in connections.
Thanks!
Here's info on the ford TFI unit: http://gofastforless.com/ignition/tfi.htm0 -
I also use the crane fireball xr3000. With the exception on the loose bracket in the shutter wheel sensor it has been great. Problem easily solved with a little locktite.
Rich0
- 112 Hudson 1916 - 1929
