Bell Crank Pads
Alex, For the pads try K-gap in Calif.0
alexa wrote:Where do I get the round "rubber" pads that are on the bell crank assembly for the clutch? Also, the tube that runs from my manifold to my carb (had heat insulation on it) is broke off, any ideas for repair?
NAPA sells a heat tube repair kit that contains a 20 in. coil of 1/4 in. aluminum tubing, brass ferrule and compression nut that fits the Carter Climatic choke threaded male fitting, a tap to bore a hole in the stove if not already there, and enough insulation fabric that you simply stretch over the tubing prior to assembling the whole setup between exhaust stovebox and the choke. Ask for "choke tube repair kit, 732-1419". Hope this helps. ArtS0 -
Alexa,
Metro rubber products also sells the pads for $10.00/PR.
John0 -
Thanks everyone for the info, I will get crate together someday and post some pictures.0
