adding an additional brake/signal light
"third" brake lights can be affixed to the rear window glass via suction cups or even if desired the suction cups can be double back taped to the glass. Run the wires via the outside of the window molding.0
Thanks Oldfarmer since my rear windows are split that would be the best option I guess as the body is a smooth slope downward and nowhere else really to mount a third light set up0
But do those light bars come as 6 volt? I may have to modify if they don't.0
>>> https://vimeo.com/120428548/be85171744
This is on a stepdown but you should try to get one that will give signals, etc.0 -
Heres the one I have. Works great!
Can mount with suction cups or supplied 'sticky dots'.
Ran the wires down into the trunk and tied into the wiring there.
Jeff
http://jandlenterprise.com/products/brakelighter.htm
Both links above are showing the same product (the best).0
Thanks guys that looks perfect!0
- 104 Essex Super 6
