Glove box light
A light bulb doesn't care if it is positive ground or negative ground. All it know is that a circuit has been made at the proper voltage.0
Ok thank you good to know0
So are you looking for a bulb or a glove box light?0
Need the housing bulb and wire0
Suggest go to a Salvage Yard and pull one from a late model car that automatically lights when door opens, then put in a 6V Bulb0
Okay thanks0
Ive also Installed the Under Hood 'Gravity Type' Lights from a Salvage Yard too...0
- 96 Essex Super 6
