1934 Hudson radiator modern replacement reqd
barrysweet52
Appreciate some help finding a modern replacement for an original 1934 Hudson radiator - is there one? I have the top and bottom tanks only. Thanks
Not sure this is really "help" - I just went to a radiator shop and asked them to make me a radiator. They made up a tank with the original style fins etc.
WILDRICK RUBBER PARTS offers new aluminium radiators for 1940 to 1954 Hudsons - they might be a resource.
There is one listed in Hemmings along with 35H drive-train for $2,000.0 -
A dodge daktoa truck radiator will work in a 1940 Hudson something was on the forum about it Google it it should come up0
I think it's from a 1987 dodge daktoa0
In 1934 the water filler was on the side of the top tank, not on the top. This and the pipe fittings can always be moved around if I find a modern radiator. I have the original solid water filler with a badly rusted threaded hole for the cap. Im thinking I could make up a large thread cutting tap to clean up the thread and then make a new screw in cap. Things we do to keep originality. I never realised that because of the very heavy fittings, they were made longer so that they reached the front internal side of the tanks for support. Thanks everyone inc Bob.0
Barry, you won't find a replacement radiator "off the shelf" anywhere. But any good radiator shop will be able to fit a new core. Be prepared for big $$$$$$ though!0
I had a 35H radiator recored at Gatton Qld with a modern style core not too long ago for around AUD1200, they got the core from a radiator core maker on the Gold Coast.
I still have the original core if you want dimensions.
Orignal style cores can be made to order in NZ I believe.
If you are missing the side straps and "wings" they would be straightforward to a person with your skills if you have access to a folder. I can provide photos and dimensions.0 -
Thanks again everyone. With all the different makes of cars I was hoping I would get lucky.0
I have just had a 35 Hudson 8 radiator re cored modern replacement using old tanks.
$1000 nz dollars0 -
Damn dude who did that?!Trevor J said:I have just had a 35 Hudson 8 radiator re cored modern replacement using old tanks.
$1000 nz dollars
I got Timaru Radiator Repairs to do mine.
Re-cored copper 4 row.
Also got them to replace and shift the bottom outlet, shift top inlet to center, shift and add a second dummy filler neck. Flick a coat of black on it. And then pop the original stamped Hudson data plates back on.
Cost $600 cash.
hmm cant find a good pic of it. Below is about all I got on hand that shows some of the work done to the top tank.
http://www.thebrassworks.net/shop/Restored-&-Fabricated-Radiators-Other-Radiators/c10_52/p403/Hudson-Radiators/product_info.html
Looks like they have done a 1935 in the past0
- 104 Essex Super 6
