34 to 39 diffs, 6 bolt CWP vs 8 bolt CWP
Yes, you can change the whole unit, but you cannot bolt the stronger c.w on to the earlier carrier.0
Thanks Geoff. Do you know if that same 8 bolt CWP centre was used in any of the 40 to 46 cars?0
Yes, the same unit was fitted from late 1938 thru 19470
