How to ID a 308 ?
paulrhd29nz
Hi all, I’m going to go looi at a 51C6 coupe.
The owner claimes it’s a 308, but he had no idea when I pointed out (from photos )that it has a 262 head on it. It also has Twin -H on it as well , with a 3 speed with overdrive. I’m going to see it in person on Monday.
So if someone can point out what determines a short block/long block 262 and what determines visually a 308 block.
I have many Hudson’s but I’m unfamiliar with the step downs.
Thank you ,and of course I will follow up with pictures.
The 308 has a reinforcing rib cast into the length of the block on both sides about two inches above the oil pan rail.0
Foundry casting numbers are 304539 for 51-53 Hornets. 310111 for 54 Hornet.
532500 for 55-56 Hornets. Number located below distributor.0 -
check out the photos, lower right - http://wildaboutcarsonline.com/cgi-bin/pub9990262549620.cgi?categoryid=9990481656451&action=viewad&itemid=9990481661744 - hope this helps - thanks for the casting #'s0
262 head on a 308 is very common0
Perfect, thanks guys.0
- 174 The Flathead Forum
- 599 Vehicles
