Replacement Ignition Coil for 37?
I have the original coil on my 37 Hudson coupe with the armored cable coming out the top (as mounted) and then goes through the firewall to the ignition switch (from what I can see). I need to replace the coil so what should I use? It still has the original 6 volt system with positive ground battery. In addition to a recommendation on a coil, what’s the best way to wire up the new coil as it won’t have the armored cable on one end.
I don’t suppose there’s a way to rebuild the old one or if it’s even worth doing? Has anyone adapted the old armored cable setup to a new coil?
You can use a 6 volt traditional bottle type coil. But the "armored cable" stays with the car unless you plan to rewire. I had a coil from Pertronix on my 39 for a short period of time. The tabs around the top of the cap your current coil are bent up and the wire inside is connected by nut and washer. AT least mine is. I had to add extra wire from that wire to reach the neg. post on the Pertronix coil and the cap was soldered to the coil on top as it set. ( I mounted the pertonix coil as my original is mounted.) I have since put the original coil back on. Went back to points and have no issue. I don't know where you can find a coil like that one as I to have been looking. Although not to hard. You can try Doug WIldrick @ 317 398 4163 or Bill Albrights @ 909 823 9168. If they don't have one maybe they cant point you in the right direction0
Doug would always be a first choice in looking for parts or repair.
I think that the Autolite coil for your car would be the IG-3224S (or IG-3224JS, which also fits mid-1930's Chrysler products). You should double check this with other '37 owners, however. These original-style coils have the tabs at one end to which you can fasten the end cap of your armored cable. Then it will look exactly like the one that's now in the car. (While you can find a modern 6-volt coil in your local auto parts store, it won't have the tabs on it, and it won't have the neat and clean original style installation.) These old style coils are fairly plentiful on Ebay, but the prices vary wildly, so shop around.
Here's one on Ebay right now: https://www.ebay.com/itm/NOS-IGNITION-COIL-1935-1942-CHRYSLER-DESOTO-DODGE-PLYMOUTH-AUTOLITE-IG-3224JS/113635607771?epid=1742191442&hash=item1a7535c4db:g:gF0AAOSwHN9cZJdz:rk:7:pf:0
Would there be any problem with this temporary set up of the new 6 volt coil to test its performance with a new coil?
My only other question on this temporary setup is if the metal cap on the armored cable which crimps to the end of the original coil needs to be grounded in some way for this to work. My battery needs a bit of a charge before I can give it a try, so if someone sees something I’ve done wrong please let me know. Again, this is just a temporary setup to see if a new coil effects how she runs.
It's okay that way, no need to ground the cap. I have read that the reason they used armored cable was antitheft, it kept the vehicle from being hot-wired.0
That's how mine was set up when I had the coil from petronix. It will be fine that way0
- 120 Hudson 1916 - 1929
- 612 Vehicles
