Terraplane front-end parts
Beforemytime
Without looking I'm thinking my '38 Terraplane might be due for some front end parts to tighten up tbe steering a bit. I went to tbe MOOG website online catalog and there is no option for Hudson. Does anybody know of a source for parts these beam axle cars use?
King pins
Tie rod ends
Bushings
Etcetera
Shocks I presume to be standard fare.
King pins
Tie rod ends
Bushings
Etcetera
Rare Parts, Inc.; looks like they sell directly, on EBay, through AutoZone, etc.
https://shop.rareparts.com/search?year=1938&make=HUDSON&model=TERRAPLANE
I see shackles, kingpins, tie rod ends, etc.0 -
I have a king bolt set I would sell you for less - prices seem high. Gert Kristiansen
HETgtkristi@comcast net (remove the HET prefix). Let me know.
I used ford tie rod ends on my 38. The taper is longer but the same taper. I might be able to find the part number if you need it.0
Thanks guys, just curious tonight. Long time before I can get under it to check it out.0
I'd check Ebay from time to time. I see tie rod ends fairly often, and they're not expensive. Also, check with some of the Hudson vendors who advertise in the WTN.0
Bob Ward first saw this info I believe many years ago .... when he wrote it. There is a page 2.0
- 173 The Flathead Forum
- 599 Vehicles
