Tachometer
Here's a possibility for a lot less on eBay. Still a little pricey factoring its history: https://www.ebay.com/itm/Vintage-Sun-RC-85-Tachometer-Sun-EB-2-Tach-Transmitter-6-Volt-6-Cylinder-Used/303069824285?_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=20160908105057&meid=76d58535caaf430d9bbff33f08b3f225&pid=100675&rk=1&rkt=15&sd=303069824285&itm=303069824285&_trksid=p2481888.c100675.m4236&_trkparms=pageci:72f0f0ea-528d-11e9-8c8f-74dbd180da80|parentrq:cc459df81690ac8938b48059fff2c569|iid:10
hope this helps - it still works!
How about a jag xj6 tach from a 73 up to 87 or so. They are electronic and just need to find a housing that will fit to accommodate the mounting location. They should be dirt cheap considering all the old dead xj6s0
