1949 hudson 2d coupe rear end HELP
Well guys I have a 49 and unfortunately the rear end has sheared some teeth on the gears. Can anyone help me out on where to looks for parts or information on what I could do to replace the 3rd member. Thanks guys I appreciate your help.
  • Are you in the HET Club? If so, there are several people we could refer you to that might have the parts.
  • What is your ratio?     Hudson rear ends on stepdowns were made by Hudson from 1948-51. They are not interchangeable with other gears from other rear ends-only Hudson.
  • You might take this opportunity to go to a better ratio for highway travel, if your present rearend ratio is unfavorable.  I believe the automatic transmission-equipped Hudsons had higher speed rearend gears.  Then, too, I believe that the post-1952 rear axles were made by Dana and the gears were interchangeable with a number of makes (unlike the gears in pre-1952 Hudsons, which were manufactured by Hudson).  That means they are more plentiful and are available in a range of ratios.
  • There should be rear 3rd members available for your housing since many have upgraded to '52 & UP Dana rears.
  • I have a 51 Hornet with OD, and 4.56 gears...sure would be nice to knock that down to 4.10 or even 3.78. does anyone reading this thread have good used gears they don't need?
  • If I were going to the effort to change gears in a Hudson built rear, I would just change the whole rear out to a dana 44. Better yet, change out to a later model rear with flanged/stronger axles.
    If you want a 4.10 hogshead let me know. I have one for a Hudson built rearend.
  • If you do get a better rearend ratio, don't forget you'll also need to find some matching speedometer gears.
    Good luck with that....
  • The odometer reads about 8% fast right now, so it will actually get closer to correct if I change to 4.10 gears. And if I care to get it closer, I think I have enough SW ratio adapter box parts left to make a box to fix it, but I doubt I'd go that far on this car.
    I am not a het club member yet but will be. This car is new to me so I’m just diving into the Hudson world. Any info I can get I would appreciate. I will finally get around to pulling the 3rd member out tomorrow and gather the final verdict in the damage.
