1937 Hudson Brake System Restoration
Ivan, I really like that idea! Can you share a picture & if possible of what fitting(s) you used? Doing that would definitely be better than forcing crud through the entire bore & possibility damaging it.
I decided to go ahead & take the backing plate off & blast it clean. I just couldn’t bare leaving it rusty or just painting over the rust. Speaking of painting over rust, good lord the POR15 is brutal to try to sandblast off! I just about burnt up my compressor when I did the oil pan a while ago, one millimeter at a time. The compressor is still running but she’s struggling along, thus I’m taking many recovery brakes so I don’t kill her too soon. Once the coupe is on the road, she can die a spectacular death!
Question: What paint do you guys use for painting the backing plates? I wouldn’t think it would get too hot to need a high 500 degree temp paint but I could be wrong.
The drum gets kind of warm, the backing plate does not.
May have had a brain fart about the purple dot 5 but my Harley's use it as specified on the master cylinders. My dot 5 could be pre 2013 since the bikes are0
Question: what can be done to remove the rust from inside the brakes drum? Can it be done without ruining the surface the pad will push against. I do plan on using the same pads I took off again.
Sandblast the drums, get them turned, get new shoes....it never ends! Or just scuff the rust off with sandpaper.(make sure you repack the wheel bearings, also)0
Sandpaper is fine
If you use sand paper witch is fine do it outside ware a dust mask don't breath the dust no telling what might be in the dust
My two cents0 -
Definitely will avoid breathing any asbestos or other nasties.
I picked up a lisle handy packer to try out.
I was starting to clean up the drum this morning & noticed the seal has some dings in it. Will it effect the sealing? Honestly I’m not really sure of the seals job here. If it’s to keep the grease from coming out between the seal felt & the hub face it mounts against, I’m not sure of its current condition. Anyone?
This may or may not help determine the need for a seal but I do have grease on this area. Not sure if that’s normal or a sign to replace?
on my 51, I screwed the retaining nut onto the spindle, then put the hub/drum sort of in place on the spindle, let it drop down some, and yanked on it, and the seal and bearing stayed on the spindle, the hub came off. Hard to explain, easy to do. It's just a no-cost way to use a slide hammer like tool, to remove the seal.I also reused the seals, and mine look worse than yours. and they'll be fine. The felt keeps most of the grease in, and most of the dust out. It's not rocket surgery, you know.0
Squirrel, I did your nut method & it worked just fine. I cleaned all the old grease out of the bearings with mineral spirits then blew air through them but didn’t let them spin. The inside hub area had been filled with grease & I saved some of it. Looks like a pile of scat!
I love old wheel bearings...I reuse them whenever possible. Made in USA.0
Just a quick jump back to brake fluid...
Doesn't Dot 5 require more pedal effort?
What about a synthetic Dot 4?
Jeff
I'd be interested in hearing a theory about why different brake fluid would require more pedal effort.I guess I'm old fashioned, I use good old Dot 3 in my Hudson, as well as my other old cars. It seems to work fine. And I don't have to worry about what is in it, when it's time to add more.0
Don't mess with re-building the wheel cylinders as new ones are only about $15. BTW, I can't answer your email as it's a donot reply thing. So here is what I sent ya.
Yes, the 4360 is correct
Seals, Rear Wheel Inner National 6356 36-54 x Jet Chicago
Rawhide 15960 Victor 49136 National 482253 Inner
National 5811
Brake Shoes Auto Zone 151 36 thru 47 Front
Brake Shoes Auto Zone 31 36 thru 47 Rear
You'll have to drill a hole in the secondary for the cam adjuster. Use old
shoe as a pattern.
Larry aka Uncle Josh0 -
Does anyone have a suggestion on spray paint for the drums? Since the drums can get hot from braking I was thinking of using 500 degree paint.0
BigSky, I have one of those wheel bearing packers that I purchased at Sears some years ago. It's easy to use and does a nice job removing the old grease while replacing with new grease.0
Ken, I got lucky a while back & was able to pick up Wagner wheel cylinders for $10 each off Amazon. I wanted to go with steel braided brake lines & a guy on eBay was selling a full set of 3 that was supposed to be exactly like original in fit for $85. Instead I took advantage of some coupons I had at car quest & bought a set of 3 & only paid $33 in total for all 3 hoses. I couldn’t pass by that deal.
Doug Wildrick has been very very helpful with questions I’ve had over the last year & try to get what I can from him.
Uncle Josh, thanks for the listed information, it’s very helpful!
- 96 Essex Super 6
