Intake manifold
As long as the manifold has a flat mating surface dry will do nicely.0
I would use blue Hylomar; it is the best and not cheap !!
www.amazon.com/Hylomar-172-148-Universal-Gasket-Sealant/dp/B00J4Z7N9I
Doug Wildrick recommended to me to use the Permatex Ultra. Very thin coating on both sides was his recommendation. Above all else, which I’m sure you know, is a flat clean surface.
