Fuel Lines
m.patterson56
I'm pretty sure I know the answer to this, but the fuel line in my 48 Super Six is made of copper tubing from the tank right up to the fuel pump. Was this original factory material? I seriously doubt it! (Ha,ha!)
I think I'll get some SS tubing and spend a Saturday fitting up a new fuel line. Single flares would probably be OK but I think I'll use double flares just "because." I might even go for an electric fuel pump! Any recommendations?
Like Ken says!0
Ken and Geoff speak with great wisdom!I like Cunifer for brake and fuel.0
Thanks fella's! I was pretty sure the copper was not OEM!
Ken is right that SS is a pain to bend but I have gotten pretty good at it and bought a tool from the UK to flare it without problems. The standard flaring tool really is not designed to work with stainless.0
What's wrong with steel? I have the same question for those who want stainless steel water pipes for Vintage era Super Sixes. They have taken 90 years to rot out. How long are you going to live to warrant a Stainless one, considering the extra difficulty in making one? I supply plain steel pipes with a 50 year guarantee! (I'm 81).0
Also we seem to maintain our old cars a bit better than they got for the decades they sat dormant.... Steel is fine.0
Is it 5/16 outside diameter . ?? Thanks John0
Thanks 540
Copper is not good to use because it will break down and start leaking in the piping. I have seen a few engine fires start this way. I go with the steel pipe. Never had a problem bending or flairing it. Measure twice, cut once or something like that...
- 596 "How To" - Skills, mechanical and other wise
