WTB volt regulator
Lklemm1
I am in need of a 4 terminal volt reg for my 232 flat head. Does anyone know if there is new ones available today at parts stores? Part number? Checked Napa with no luck so far.
If you want an AutoLite VRR 4001A I can sell you one. The problem is ,what year is your Pacemaker engine? The 51-2 Pacemaker 232 uses a VRP 6101B regulator which is a 3 lug type used on 2 brush generators. The only exception for the 1950 Pacemaker using the 4 lug regulator is if you have a 3 brush generator left over from previous production. 1950 was a transition year for the electrical generation system with the 2 brush system coming in in mid production. Some 1950 Hudsons had 2 brush systems and others had 3 brush systems so it depends on what your generator is. In any event I have both types of AutoLite voltage regulators and a bunch of NOS Allstate NOS 6 volt voltage regulators.0
Lance i sent you a pm.0
