Fuel regulator query
Old Fogey UK
Having given up trying with the worn-out Carter W1 on my 1934 Hudson Eight, I bought one of those Zenith 228 lookalike "Universal Carburetors" from Daytona Parts. Has anyone else used one of these carbs? Any problems with them?
I want to run the carb with an electric fuel pump that delivers 5 - 8 psi.
I guess I'm going to have to reduce the pump pressure with an adjustable regulator - please could I have some suggestions what pressure I should set it at ? With the old Carter, it didn't matter what pressure I set it at, it still over-fuelled!
I use this Carter rotary 6volt fuel pump for priming my '51:The fuel pressure seems about right.I've considered abandoning the mechanical fuel pump and running off this exclusively.
I have a Zenith on my Jet, with an adustable main jet, and works just fine.0
- 85 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 591 Vehicles
