Adding Overdrive
So I have no direct first hand information. But back in the day there were add on units for these old(der) cars. I think you would be hard pressed to find one of the 20s vintage. On a different note I know all the 1916s that competed in the Great Race had custom overdrive units. Most were of electric activation. However, I did talk to a guy when the race started in Riverside who had his 1917 Hudson that competed in the race in the 1980s. He had his stock transmission modified and added a 4th gear which activated with a lever. I tried to ask additional questions but I did not get far. But when you looked inside there was an overdrive lever which seemed to be attached to the stock trans. I looked under the car and there was no unit behind the trans. So I have no idea what he did, but if you have the money you can do anything.
Sorry not much help. He also convert to front brakes. Remember if you go fast you have to be able to stop fast. Something these vintage cars did not do very well.
Jay
Your best bet would be to find a higher ratio 1928 or 1929 Hudson gearset, which would bolt right into your housing. the 1923 models had 4.45.rear end, and the higher option for 1928 and '29 was 4.1, which reduces engine revs by 10%.. As mentioned, if you have enough money, anything is possible, but considerable engineering is required to fit an extra overdrive unit.0
To your question of changing the rear end. In my 39 an O/D was added. I didn't change the rear end but the drive shaft was shortened. and my frame was cut slightly to make it fit. But not sure how a 23 is set up. Best to you in your endeavor0
Agree with Geoff. I found a 4.1 ratio diff. Wire brush around the pinion flange near the oil filler and ratio should be stamped there.0
Another possibility is to replace the gearbox with a modern 5 speed, 5th gear is typically a 15% overdrive.0
- 109 Hudson 1916 - 1929
- 176 The Flathead Forum
- 605 Vehicles
