Hudson 397093 intake manifold
dnaill
Greetings to All,
I am cleaning out an old farm shop in Maryland and have discovered an intake manifold with two single barrel carburetors. Hudson 397093 is in the casting but have no more details. I would like to see this go to a good home and be appreciated.
David
David
Got pics
Where are you in Maryland?
New Windsor0
This wonderful relic has stirred much interest from multiple sources, so I will let the marketplace sort it out.
It is on eBay : http://ebay.us/3xIQgO?cmpnId=5338273189
wow, looks like it was literally buried in the barn0
So the part number says 307093. It will fit all six cylinder Hudson blocks from 48-56 except the 202 cubic inch engine used from 53 -56. It had the external balance tube, so it was not in a 55 or 56 Hudson. The carb. base bolt spacing would need to be checked to see if it's Wasp or Hornet, or someone with a parts book look up the correct number and see the application.0
Is this the correct manifold for a 52 308 ?
my master parts catalogue lists a 307183 as the correct manifold
Dave
Casting numbers and Hudson part numbers are rarely the same, Twin H Manifold for the 262 has the same casting number, difference is in the carbs and carb mounting spacing.0
- 86 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 593 Vehicles
