262 head max milling?
It's me again. I've learned from my machinist that the 262 head mounted to my 308 is in need of a shave. Can anyone tell me wha the minimum final head thickness should be?
Thank you
  • Ck if its ever been shaved previously then it should measure 2" originally, so I suggest mill .060 - .080 safely. (However, Ive milled them much further then installed short reach s/plugs).
  • Factory spec was a max of .060 or total thickness if 1.94".
    The thinner it is the more it "squashes" the combustion chamber.
  • just learned that I'm at 1.960 after the necessary milling!
  • Good to go!
