Palmy's Winter Project
Update April 28th
Hello fellow Hudsonites,
I was so close to finish the testing and put Molly out for a spin, but the transmission was showing a small leak around the control lever area wich postpone the drive. I'm feeling a bit discouraged to be unable to drive the car as driving it was missing me so much, but I've got to find the solution before I even drive her out.
The leak is located somewhere around the control lever and one of the band's adjustment screw, but I don't know exactly where it is and how to fix it yet. Feel free to send your suggestions for this one, I really need it.
I'll keep you updated as soon as possible.
Your Autistic Hudsonite,
Max0 -
Update May the 5th:
Bad news:
Today I got Molly out for a spin and after a 10 minute ride, once back to the garage I've looked under and saw that the transmission is leaking as much as before and still at the same place between the torque converter housing and the transmission itself.
Right now I don't know what to do and I'm still in shock to see that the work I've done so far seems to disapear as if nothing happened.
I'll be looking out for any way to properly fix it once my mind cleared.
Max
