1930 Essex
Back to the top... any help?0
Try Barry Davis in NZ. HETbarrysusan1930@gmail.com (drop the HET) He has both a '30 Essex Challenger Sedan & a '30 Essex Country Sedan
Thank you ESSX28-1. Do you know anyone with a coupe?0
file:///C:/Users/hajac/AppData/Local/Packages/Microsoft.MicrosoftEdge_8wekyb3d8bbwe/TempState/Downloads/1930_hudson-essex_reference_sheets%20(1).pdf
Why not use the references in Alex's data in this club.
Glass sixes for 30 Essex is here.
What I'm looking for I a measurement of the window opening, and the distance from the top of the beltline to the bottom of the window opening, for a COUPE. this is for a person who is trying to recreate the missing rear window area on the back of his car.Hans said:file:///C:/Users/hajac/AppData/Local/Packages/Microsoft.MicrosoftEdge_8wekyb3d8bbwe/TempState/Downloads/1930_hudson-essex_reference_sheets%20(1).pdf
Glass sixes for 30 Essex is here.0 -
I see a number of 1930 Essex Coupe owners listed in the roster. You could contact them directly and ask for help.0
You could try Graham Sussey. He had a 30 Essex Coupe & may still have it.
Graham Saussey, at HETcview@xtra.co.nz
