drop out rear differential
Can someone tell me where the stamped ratio would be located? Or is there just a stamped code somewhere on the drop out housing?
To identify the ratio of the Hudson (not Dana) type rear axle a number is stamped on the flange of the differential carrier where it is bolted to the housing. See the "5-9"?
thanks. now i know where to look. does the 5-9 mean 4.59 ratio?
For 1948-1952 Hudson axles:5-9 is a 4.55:11-10 is a 4.11:17-12 is a 3.56:10
that helps me a lot, thanks
