1932/33 hudson super 5 window coupe windshield frame and pass door latch assy.
32hudsonhotrod
needed 32/33 hudson super coupe windshield frame, pass door latch assy. driver door window regulator.
wanted 1932/33 coupe interior parts, window garnish mouldings0
Photos and dimensions might help (and you could also e-mail them to Hudson vendors who advertise in the WTN). Some people might have accumulations of unknown Hudson parts, and not know which years they fit unless they had a photo of them.
Also, this is definitely a Hudson, not a Terraplane?0 -
https://windshieldframes.com/
This place can fab them...if yours is a '32, did you remove the visor? Either way, you'll need to give them perimeter measuremenrs.0 -
thanks for your help0
I have some 4 dr 33 terraplane parts doors. Possible window winders will work on2 door.. I will have latch mechanisms for 4 dr aswwel. Try to find out if interchangeable. Do u have some of your drivers winder.glass in a 4dr is much shorter. Latch parts would be same. Cleansweep@xplornet.ca
Post a picture of your dash gages. . If your car is 32 or33 Hudson or early 32 essex. It will b a different body than a terraplane. Post pictures of front fenders . ur car might b a 3 terraplane with novisor
