Who makes best leaf spring replacements?
airbrushguy
Took springs down while replacing rear axle in my '49 Super. Noticed spring bolt is
barely long enough to reach into hole in axle's saddle. Thinking it might be good time to replace springs.
Any suggestions for where to get replacements?
Thanks
Thanks
Looks like they have some at 21st Century Hudson. https://21stcenturyhudson.com/hudson_chassis_parts.html
I own a pickup and not a stepdown, so no experience here, but I have looked for other parts at 21st Century Hudson with success.0 -
Website will not let me enter.0
Is it possible to just replace bolt?
If so, what size is it and does anyone have advice from experience?
Thanks0 -
I have ordered springs from Eaton before, but Randy might be cheaper. (he probably gets them from Eaton too).
Replacing the centre bolt is very doable.
Leaf spring centre bolts are specials with a tall round (1/2" dia?) head that engages with the locating hole in the axle, most spring shops will have or can readily make replacements. From memory Hudson used 5/16" dia spring bolts.
You will need to be able to keep the spring leaves clamped together during the replacement process, either that or let the spring shop do the replacing, its something they are set up for.0 -
Eaton is pretty much the only game in town unless you go to a spring maker that will build them for you from specs they have. I would also imagine Eaton is where Randy gets his. Shipping is expensive due to weight.
https://www.eatondetroitspring.com/findmyvehicle/
I have cold re-arched springs successfully using a hydralic press.
https://m.youtube.com/watch?v=CYWfYyYQ2kA
