rear glass
Can someone tell me what rear window glass interchanges with the 52 & 53 hornets?Do the coupes swap with 4-door sedans. They look close.Are these being reproduced?I have an old "swaps" book I got from the late Lew Backus, but it doesn't have that info.Ron S
52-53-54 sedan and broughm are the same, coupes are different0
Thanks.Does any one reproduce rear glass?0
no one reproduces the rear glass. i have a 51 coupe rear gllass at my brothers farm in western penna, if onyone needs it. have a lot of sedan rear glass, but have restored every coupe I got, so no coupe parts cars, BILL ALBRIGHT0
Coupe rear glass available in Indiana0
Any advice on getting the rear glass in and out without breaking it, I have to replace the stuff around mine in the near future. It is a 2dr pacemaker.0
Alex Yes Take Off The Trim With A Screw Driver Then Take A Razor Knife And Cut The Rubber So The Glass Will Just Lift Out With Out You Prying On It I Have Done It Many Times I Would Use New Rubber From Kgap When Installing The New Glass It's Not And Easy Fit Good Luck Andas Frank Spring Said There Are Some Good Rear Coupe Glass In Indiana.0
- 182 The Flathead Forum
