Jet tires
What is the optimal / ideal modern radial tire size for a Jet with stock 5 x 15 inch rims? What should the width of the tire be and how wide should the tread surface be? Any advantage to going shorter or taller, narrower or wider? Since I am not going to use wide white walls on my new (to me) Jet there are many more options.
I run and know many others who run the 165R15 tires from coker tire with no issues at all.
