Remove Vibration Dampener?
2»
  • Gear looks fine.  you need to check the advance springs, pegs, slots, points pivot, contacts.
  • BigSky
    edited July 2020
    A good friend sent me a replacement OEM harmonic balancer and unfortunately it broke in shipping.  However, I compared the one I took off and the one sent, 13.2lbs vs OEM at 12.2lbs.  One can definitely see an overall size difference as well.  My questions;  1) are the engines internally balanced?  I believe they are but I’m not 100% sure.  2) would the weight difference of the harmonic balancer effect the engine? 3) does anyone other than Wildrick’s sell the btonze cam thrust washer?  I’ve called multiple times & can’t get the basic question answered, “does the cam thrust washer fit both the 6 cylinder as well as the 8 cylinder?
  • Yes, thrust washer fits all models. I would use the original dampener.  All Hudson engines were dynamically balanced.
  • You can think of the splasher 6 and 8 as pretty much the same engine with different numbers of cylinders. Going forward from the front of the block everything is interchangeable, front plate, timing gears & cover, thrust washer, pulley, pulley spacer.
  • I need to locate the bushing / sleeve that the timing cover seal rides on anyone know where I can find it or can I just flip mine backwards?  How much play should there be With this sleeve against the crank?  I’m a little worried it maybe worn too much on the inside to flip it.
  • It is held firmly in place by the crank dog, so just turn it round to get extra life.  otherwise buy a new one from Dale Cooper.
  • Try and use sealant to stop any oil or water leaks where bolts go thru anywhere on the motor/gearbox/diff. Its been a long journey for you with all the repairs but the enjoyment at the end will be worth it. Also others have also learnt a lot because of your pain :)
  • So as I looked at the cam head I was wondering how much, if any, I could move the cam forward with just a small prying of the head against the block?  Now the distributor & oil pump are still in place & not removed as are all the valves, springs & lifters.
    So I very gently pry’d and with only very gentle pressure, like a pound was all, the cam head moved forward a lot!  I slipped a 1/8” thick washer behind the head with room to spare.  So is the cam supposed to be able to do this?  Is this a sign of some kinda problem which needs fixing?  Once the cam thrust washer is in place (& everything back together) at only 1/16” thick, what is going to keep the cam from pushing forward & bounce forward & back in the 1/16+” of space I’ve just found?
  • The peg that is sitting in  the nose of the cam should have a strong spring behind it, and the peg bears on a thrust pad on the timing cover.   The angle of the gears ensures that the cam will be forced back against the  thrust washer during use.
