piston pins
redrider
Hey Guys. how do you remove the piston ring pins? 1948 super six
You don't!
how do you remove the rings, if you do not remove the pin?0
carefully, with a ring tool that expands ring by pushing ring ends away from each other0
the replacement ring are not compatible for a pin?0
If you are using the pinned piston the rings for it will have ends that fit around the pin. Dale Cooper sells the correct rings. Otto machine works also... check my website for Ottos contact. Ken Cates0
I bought ring already, not the pin type,do I have to remove the pins? that is my question, how to remove the pins?0
No, you cannot successfully remove the pins. if you did you would have a compression leak. You can file the ends of the rings with a small round file to fit around the pins, or you can get the correct rings. What model engine are we talking about?0
262 ci 6 cil. model 481 1948 super six0
- 612 Vehicles
