what a heap! (pic test)
the guy we got this car from installed this '53 303 Olds and Hydra-matic around 1955.one of the ring locator pins had worked its way loose and hammered into the head of the original 262,so being a young punk hot rodder the Olds swap seemed pretty logical at the time.my apologies to those of you who don't like brand X engines in Hudsons.i'm the same way most times,but this one was priced right and easy to get running.next up is scrubbing off all the old scrungy paint,UGGHHH! -george0
George, is the motor and tranny for sale?
John
That Hudson is in GREAT condition when compared with what I've got to work with... All the metal is there, even all the technics! Please don't call it a heap, doing so makes my Pacemaker closer to a pile of scrap metal... I wouldn't like to think so!
Cheers,
Hannu from Finland0 -
[ QUOTE ]
John
[/ QUOTE ] not for sale unless i install the 394 in the backyard,but i know Olds guys all over,if you need Rocket power stuff.0 -
[ QUOTE ]
[/ QUOTE ] it IS in great shape,only rust is bottom edge of the trunklid,the 2 front hood corners,and a little spot on the inside rocker drivers side.it'll probably take 2 days to fix all of it.oh,and the doors sag a little,but it doesn't look like any big deal to fix,maybe some new pins.when i say "what a heap" i add this
so you know i'm mostly kidding.the paint is what makes it look bad,and i'm in the middle of scrubbing it off.good luck with your pacemaker-george 0
