Clifford Performance - HUDSON PKG
it may be of some use to know exactly what problems you are having. Clifford is about the only option for performance items for Hudson H6s.0
I’m running a Clifford manifold and long tube headers (which they don’t make anymore). The intake is topped by a 500 CFM Edelbrock carb. Lots of other mods to this engine. This setup works great in our 40 two door sedan.0
50C8DAN said:it may be of some use to know exactly what problems you are having. Clifford is about the only option for performance items for Hudson H6s.0
54coupe said:I’m running a Clifford manifold and long tube headers (which they don’t make anymore). The intake is topped by a 500 CFM Edelbrock carb. Lots of other mods to this engine. This setup works great in our 40 two door sedan.
Hi 54coupe, do you have any pics you can share with me?0 -
Not sure anyone is running the 2bbl Weber on their Hudsons. I know Clifford pushes them like crazy. They are supposed to be a good carb. You will need to make your own linkage however, not sure the factory linkage will work and I don't think Clifford sells one. There are a number of guys running the headers and manifold however, like 54 Coupe using a small 4bbl.0
Here is another option to put on the Clifford manifold! 2 bbl TBI - https://www.jegs.com/p/Holley/Holley-Sniper-2-bbl-EFI-Self-Tuning-Kits-Accessories/5406244/10002/-1
Still another is Hamilton FI, Bill is a Hudson owner and occasionally posts here:
http://hamiltonfuelinjection.com
https://www.youtube.com/watch?v=2KaScjlo5Ag
Be sure to adjust the valves before installing the headers!
No kidding, you will need to remove the headers the next time you adjust the valves!!! Not a fun job.0
- 86 Hudson 1916 - 1929
- 11 Upcoming Events
- 74 Essex Super 6
- 28.4K HUDSON
- 990 Street Rods
- 72 Hudson 8
- 592 Vehicles
