Like another hole in my head
ski4life65
Just picked this up. Needs a new flywheel. Half the teeth are missing.
NICE!!!! if a flywheel is all you need then you will have a nice driver0
Wow nice car Don, but remember, we all need more holes in our head, lol. I have 13 and need more0
Sweet!
I'm so jealous....
Hmmm..the wife did say I need a hole in my head!0 -
Original CO plate or is that a reproduction?0
superwasp said:Original CO plate or is that a reproduction?
I am pretty sure it is original. I am not sure which county is from.
Ken U-Tx said:Ring gear is what you need, flywheel is separate. New RING GEARS are available from Jason Fisher at Vintage Coach in Fontana, CA for $75.Ken U-Tx said:RING gear is shrink fit to flywheel. It is heated up with a torch to expand and them set on the flywheel and allowed to cool. It contracts and is firmly attached to flywheel.
I had a couple of used flywheels on a shelf, but new ring gear is probably a better answer. Do I just heat up the torn up ring gear to get it off? Or is it a little more complicated?
I was given a 1929 flywheel with many stuffed teeth, as well as a good used ring gear. I cut the damaged ring gear off and then found the used ring gear spun around on the flywheel. The flywheel had been machined down in the past. You can get ring gears with different inside diameters. Working on old cars you have to expect the unexpected.0
- 102 Hudson 1916 - 1929
- 16 Upcoming Events
- 90 Essex Super 6
- 28.5K HUDSON
- 554 "How To" - Skills, mechanical and other wise
- 992 Street Rods
- 172 The Flathead Forum
- 73 Hudson 8
- 597 Vehicles
