window rubbers
fasthrdking
where can i buy a set good quality window rubbers for a '41 super six ?
Just to clarify: you're looking for weatherstrip for windshield? Or rear window?0
rear window and rear door windows,
Try Metro rubber car parts good luck0
Wildrick Rubber Parts sells the proper, Hudson specific items that you need. They are in Shelbyville, Indiana0
Thanks for the help !0
I sell the window run channels, fuzzies (Beltlines) and division bars for Hudson's. thez@verizon.net , see add in the WTN.
VicTor Z0 -
I just bought a 29 Super Six coupe. I need some pine cone window cranks. Also, the previous owner installed all rubber window channels, making the windows extremly hard to open. I am sure that the original window channels were felt. Am I correct? If so, I could use a set as well as the beltline rubber. Thanks, Gary in Charleston, SC ph: 803-543-01520
I can get you a set of pine-cone pattern window winders made. The moulds will be at the foundry shortly for an order, so contact me right away if you want a pair. The channels should be felt lined. NZgeoffclark@xtra.co.nz (leave the first NZ out).0
Hello Hudsonskid, see attached pics: With or without beading.
- 182 The Flathead Forum
