brake splash guard with rubber, picture needed of the metal guard
Mark Villano is working on a stepdown convertible and is needing a picture of the metal guard so he can
build or buy one. He has the rubber part.
Anyone have one you can photo?
(Do you happen to have a photo
showing the splash guard flap that covers the master cylinder. I have the
rubber piece but am missing the steel. I can fabricate the necessary
piece if I have an idea of how it is installed. Thanks for your
help.)
Ken U. used to have repops for sale. Very nice piece.0
Ken U’s guards are a perfect copy, I have one on my 51.0
Kerry this is the rubber , the mount is just a flat piece of steel .org enough the mount the rubber then bolt to the frame with screw thread bolts. 0 -
looks easy to make yourself.0
Thanks guys, I had forgotten that its just a piece of flatbar. I sent this link to Mark.0
Here is the guard I made before I knew anything about an existing stock guard. Not sure why, don't know what it would keep from happening ! {brake line disconnected in photo}
Also, shows remote fluid holder connection to MC, supplementary air horns, power brake system, burglar alarm horn, and a section of the 1000 LED lights on the bottom !
