Need photo of Clifford 4bbl intake
I am still working on designing a new Hudson 2 x 2 intake. Clifford (Larry) has abandoned the project so I am pretty much on my own for this. Can someone that has a Clifford 4bbl intake take photos so I can see where and how the hot water plenum is designed into the manifold? Posting here would be fine.
Thanks
Thanks
I just emailed you two photos. I don't know if they will be of help or not, but they are the only ones on my phone. My engine is back in my car, so i don't know if I can get one of the under side. I'll check when I get home tonight. I emailed to the address in your profile.
Dany0 -
I also sent photos to your Email. Photos from the top! VicTor0
Clifford 4 barrel
29 is there a water inlet and outlet to this manifold?0
Here is the outlets in/out on my Clifford 4 BBL. Looks like some corrosion on the inlet!
No water inlet or outlet on my manifold. Maybe it’s an early one or later one?
Looks like Clifford made some changes along the way in adding the water heating to the manifold. The current Clifford websites note the water heating improvement.0
The photos from 29 are an early Clifford manifold that used a plate below the carb with water routed through it. The one on Victor's car is the new unit.0
