Distributor Differences
The "B" distributor is for 262 and 308 engines, and has less advance curve than the "A", which is for 232 engines. Probably has stronger springs on the flyweights.0
Geoff, Thank You for the explanation. The car originally came with the IAT4009A distributor, It never seemed to run right when hot and would periodically experience 'Pinging'. I am rebuilding the IAT4009B distributor and will be installing it after I order a refurbished vacuum advance from Wildrick. Thanks again, Tom0
IAT 4009 was a distributor for the 51-2 Pacemaker only. IAT 4009A was for the 51 model line excepting Pacemaker. The IAT 4009B was for 52-4 Wasp( 262), Commodore and Hornet line. IAT 4203 was for the 53-4 Wasp(232)0
Lance, Thanks for the extended clarification. Tom
My pleasure.0
