A Mystery ?
After removing the rusted out bolt's and nut's on the inner fender of my 54 to get to the valve cover's i removed the blasted thing and tipped it up and lo and behold if about a pint of engine oil didn't come out of the vacuum cannister when i tipped it up, is this some kind of new filter system? All kidding aside, any idea's? Thank You!
Fuel pump , sucky oil through shaft at vacuum diaphragm0
Thank You! there is so much to learn about these cars from knowledgeable people like yourself. These forum's are so helpful, Thank you again. Chris0
- 97 Essex Super 6
