EXHAUST MANIFOLD STRAIGHT 8 1930-1952
I´m looking for an inlet and exhaust manifold for my 1934 Hudson 8 (254)
The question is. Must be exactly a 34 manifold ? Or the Hudson manifolds from 1930 to 1952 straight inline 8 are the same or can be fitted straight ahead?? The Exhaust manifold seems to be the same for diferent years, but not sure.
Thank you for the advice
Regards
Carlton
Regards
Carlton
1933 T 8 and 34,35,and 1936 will fit your block. Exhaust ports and 2 barrel carb make 37 and up not suitable.0
Thank you very much for the infoRic West IN said:1933 T 8 and 34,35,and 1936 will fit your block. Exhaust ports and 2 barrel carb make 37 and up not suitable.0 -
To expand on what Ric said, some of the exhaust manifold studs on the 37 to 52 engines are in different positions to those on the earlier engines. The early and late manifolds won't readily interchange.0
Seems odd that they will not fit, being I had run a 49 wide block manifold on my 33 T 8 for 20 years. had to shorten the front outlet tho.Ric West IN said:1933 T 8 and 34,35,and 1936 will fit your block. Exhaust ports and 2 barrel carb make 37 and up not suitable.
Can someone explain how the heater works in the manifold for the carburetor? Is it automatic? Manual? I'm in the middle of reassembly. Thank you
It is supposed to have a flat coil spring holding the valve closed when cold, as things warm up it loses tension and opens up completely to allow the exhaust gas to go straight through instead of around the inlet chamber. Usually these are either seized or the spring is broken/missing. Make sure the valve is open, and secure it in that position.0
I have all the pieces intact. Visible in the photo of the engine before renovation. Even the spring is still in good condition.
Cold position. Photo 1 or 2?
Original spring and system 1934
Photo 1 is cold (exhaust gases go straight past butterfly)0
Thank you;top
I remove the valve on my 8’s and put a bolt in the bottom of the manifold. And make a cover for the top. Unless you are driving your car in cold weather you don’t need the valve. And when they are frozen you end up with a cracked manifold.0
One more question. In the cold position;photo 1;when I put the spring back on;I have to tighten it? If I stretch it, the axis turns in the hot engine position. What is the right method to mount the spring?and to answer 29sptphaeton I like to stay original; it's been 90 years that the car is like that0
Mine was original, after I peeled the furnace cement off the crack, I put an NOS original manifold on it without the heat flap so it will never crack. I’ve also replaced cracked cracked manifolds on jets because of frozen heat flaps. When they set in storage for winter in cold climates they can seize up.0
It has been at a standstill since 1954 and the flap was not seized
You’re a lucky guy.0
If you are keeping it original, the spring should hold the valve in the closed position when cold. As the manifold heats up the exhaust gas pressure will open the valve.0
Closed c is good photo 1?
Because if I put like photo 1 and I mount the spring. It turns the valve as in photo 2?
The is how it should be. The exhaust gas pressure opens the valve, which is held closed by the spring when cold.0
Thank you.Top for all good advice0
It is posed. It's progressing
