Hydra-Matic compatibility question.
Which Hydra-Matics units work in a 54 Hornet? From what other Models/years? GM cars? I am looking to replace the DG200. Making a crossmember is no problem. I would love to put a manual transmission in this car, looked into 5spd swaps but it appears to be ... not easy. I would also consider T85 but would want it to be floor shift. (Not sure if that's even possible).
Thank you. 0
If you are determined to remove the DG200 there is a step-by-step instruction PDF on my website https://hudsonrestoration1948-54.com/index.html Select the transmission page and the article is entitled converting your automatic transmission to Hydramatic0
Ok. Thanks for your reply.0
