Terraplane 1935 piston 0.015 oversize wanted
BScar1935
Hi folks,
I bought a new old stock set of pistons for my 1935 3.5 liter Terraplane engine. The engine got rebored and when we wanted to fit the pistons, it turned out, that one of the pistons is standard bore. Now I need an oversize piston - new or usable second hand item. Please have a look at your shelves.
Thanks
Chris, Germany
So you need the piston exactly .015" o/s or is that the bore size? Do you need pinned or non-pinned ring grooves?0
Hi Geoff,the piston shall have 0.015 oversize. The pistons I already have are pinned and are + 0.015.ThanksChris0
I have one that is .0165" diameter oversize (good used). You could either machine the piston or hone the cylinder. Yours for the cost of postage. It is split skirt, not T-slot.0
Hi Geoff,thanks a lot for the offer. Would you mind to take one or two pics so that I can check, if it of the same type as the other ones that I already have? please email to: c.willer@antonwiller.de or whatsapp to +4915116627002Thanks a lot0
- 120 Hudson 1916 - 1929
- 612 Vehicles
